This page provides a technical deep dive into the engineering and operational logic of the SolarFlow 2400 AC+. Understanding these core principles will help you maximise the efficiency of your AC-coupled energy storage system.
uses a high-speed bi-directional converter to manage the flow of electricity between the grid, your solar panels (via their own microinverters), and the battery.
AI-driven scheduling based on real-time Time-of-Use (TOU) pricing.
Antenna: Wireless communication antenna for system connectivity.
Button: Front control button for basic system controls.
LED Light Strip: LED indicators for battery level, output status, and IoT connectivity.
| LED Indicator | LED Description | Detailed Explaination |
Solid Green | powered on and operating normally |
Blinking Green | The device is functioning normally, and the off-grid mode is active. |
Blinking Red | A device error has occurred. Please check the app for further details. |
Solid Green | Stable and normal Wi-Fi connection |
Blinking Green | Waiting to connect to Wi-Fi |
Blinking Red | Wi-Fi connection is lost |
Blinking Yellow | OTA update in progress. |
Solid Green |
Battery is operating normally and connected. Battery status is indicated by 4 green LEDs:
Example: At 60% battery level, three green LEDs will be illuminated. |
Blinking Green | Charging the Battery |
Slow Red Blink on First LED | Battery level below 5% |
Solid Yellow | Indicates the battery level and the battery is in protection mode. |
Solid Red | Battery error detected; check the system for troubleshooting. |
Slow Yellow Blink | Low temperature detected; the battery pack is heating to reach operational temperature. |
