For users requiring a more stable connection than Wi-Fi, the SolarFlow 1600 AC+ includes an RJ45 port designed for physical RS485 communication with smart monitoring devices like the Zendure Smart Meter (3CT-S or 1CT-S).
This port facilitates high-speed data exchange between the battery system and your household's digital meter to ensure real-time energy scheduling and accuracy.
To ensure signal integrity and prevent hardware damage, you must adhere to the following electrical logic:
Twisted Pair Requirement: RS485 A (Pin 2) and RS485 B (Pin 1) must be carried on the same twisted pair within the cable to mitigate electromagnetic interference.
Ethernet Prohibition: This port is NOT an Ethernet port. Do NOT connect it to a network switch, home router, or Power over Ethernet (PoE) equipment, as this will likely result in permanent system failure.
